marc001
- Sep 28, 2013
- Howard City MI
- 2014 Yamaha Apex SE 2017 Yamaha SideWinder LTX LE
I've read the manual and I know what the mechanic told me about the break-in miles on a new 4 stroke, but does anybody have other ways of engine break-in? I'm not putting a load on it or holding full throttle. Keeping it below 6000 rpm for the first 100 miles or so is tough! Wasn't sure about 4 stroke break-in miles, I've only had two strokes in the past. Thanks!
cmharcou
Best thing to do in my opinion is to find a flat stretch of trail adn hold it wide open for 5-10 miles. Then shut it off until its cool and do it a few more times. It'll run forever then. It heats it up and seats the rings good.
ranger1
One of the most important things to remember is to vary the throttle/speed. Do not maintain the same RPM. Good to crack her open once & awhile also.
jagabom
On my machines I like to go for a 50 mile drive. Going from zero to 6000 RPM and then back down to zero. This takes a long time but I like it. Seats the rings at all RPM's. A snowmachine is an engine also. I like what the manual says.
Jim
08 APEX
Jim
08 APEX
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
Just change the oil and filter after 500 miles, that is the best thing for the engine.
After the engine is at operating temperature, I would hold mine until it hit around 9-10,000 rpm and let off. I wouldn't do any long constant rpms. Varying the engine speed is important. I did this combined with normal trail riding for the first full tank of gas, around 80 to 100 miles, when I broke in my sled this way 11,000 mile ago. I never had any oil usage issues. Everybody has their own way of doing this. This worked for me. There are a lot of threads and opinions on here about break-in.
Riceburner
- Apr 14, 2003
- N.B. Canada eh
- SideWinder LTX 50th
marc001 said:I've read the manual and I know what the mechanic told me about the break-in miles on a new 4 stroke, but does anybody have other ways of engine break-in? I'm not putting a load on it or holding full throttle. Keeping it below 6000 rpm for the first 100 miles or so is tough! Wasn't sure about 4 stroke break-in miles, I've only had two strokes in the past. Thanks!
Are you using it already? If so you are too late.
If not, heat cycle it 3 times over three days at between idle & 3,000 ish rpm or so. Take up temperature until the heat light comes on and a little more. [once heat light comes on take your hand off throttle so it will auto shutdown if it gets to max temp.]
When you ride it first time put on an old belt and load and unload it a lot for the first 300 miles. [Throttle on - Throttle off] You need to load it. I believe Yamaha says no " sustained" operation over 6,000 etc. They do not say don't go there at all as I recall.
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
Good read here, and like what has already been mentioned, you'll see heat cycles is very important.
http://motorcycleinfo.calsci.com/NewBike.html#BreakIn
