YAMMIEGOD3:16
- Apr 14, 2005
any oil filling procedure i should do refilling system. 3:16 (yammie tony)
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
I did mine last year,
I just filled the oil tank like I was changing the oil than start the sled for a minute than refill the tank to dip stick level...
I would just fill oil up to dip stick full line, start it up let it idle for a few minutes, shut down and check for leaks then check/fill to proper level.
After that you should be good to go.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
sideshowBob said:I would just fill oil up to dip stick full line, start it up let it idle for a few minutes, shut down and check for leaks then check/fill to proper level.
X2
