Yannie
- Jan 5, 2014
- Winnipeg
- 2010 Yamaha Nytro RTX
I changed all 3. The common one is the fuel relay but the other 2 can fail for the same reason, freezing up. You wouldn't want to loose lights at night or loose your cooling fan.
comatoast218
- Nov 11, 2014
- Superior, WI
- 2011 Nytro xtx
I need a list here, lol
So far within the next few weeks will be
Spark plugs
Exhaust donuts
driveshaft bearings
oil/filter change
new relay(s)
clutches gone thru/repaired + Hauck Clutch kit
Front end bushing kit ( ? )
Anything else you guys can think of thats a good preventative maintenance fix, or a "since im in there, might as well fix , repair, replace it " fix?
Extroverts sound nice but I think Ill hold off on that until I get a different track.
the oft and the seat seem nice, but I'll wait on that.. Im coming off a 97 sx700, so ATM to me its like comparing a Lexus to a geo metro..
It already has dual runners on it and they seem great..
Limiter straps replaced already
has dupont slides with about 3K miles on them and they still look great
Would like to get a skid plate as I hear they help quite a bit, as well as any other options/accessories that are worth the $$. So where are some good vendors to buy parts ( Port Yamaha I'm guessing is a popular choice, and to buy accessories for the Nytros?
Spark plugs
Exhaust donuts
driveshaft bearings
oil/filter change
new relay(s)
comatoast218
- Nov 11, 2014
- Superior, WI
- 2011 Nytro xtx
What are the 4 relays?
Lights
fan
fuel
The light relay cannot be replaced tho, correct?
Yannie
- Jan 5, 2014
- Winnipeg
Load relay.
The headlight relay cannot be replaced.
comatoast218
- Nov 11, 2014
- Superior, WI
- 2011 Nytro xtx
Load relay.
thanks just saw the diagram and see the load, light and fuel are the same relay.. headlight is not available in sold state, but should i replace it with another stock one? or maybe just have one on hand? Im assuming its not too pricey
Yannie
- Jan 5, 2014
- Winnipeg
Don't know the answer to that. Your choice, I don't carry one.
comatoast218
- Nov 11, 2014
- Superior, WI
- 2011 Nytro xtx
This is going to be a dumb question.. But just wondering if I should worry about the clutch.. Seems to rattle quite a bit, and not hearing how a new nytro sounds , I have nothing to go off of..
https://www.youtube.com/watch?v=lkNYtidNPIE&list=UUPARq9SOgx9pWUicXh7MX1A
https://www.youtube.com/watch?v=tcqJsAQUPOM&list=UUPARq9SOgx9pWUicXh7MX1A
herndonp
- Nov 28, 2012
- Freedom,NH
- 2012 Yamaha Nytro XTX
Pretty much all of them do that. Schmidt bros has a quiet kit that tones them down. I believe its $15. I put it on my sled and the wife's Vector and it made a difference in the amount of noise. You can just live with it as well.
Pete
Pete
comatoast218
- Nov 11, 2014
- Superior, WI
- 2011 Nytro xtx
ok thanks.. Im just not used to my 97 actually being quieter than the nytro at something lol..Pretty much all of them do that. Schmidt bros has a quiet kit that tones them down. I believe its $15. I put it on my sled and the wife's Vector and it made a difference in the amount of noise. You can just live with it as well.
Pete
Once its at the shop and the clutches are gone through , and the kit is installed Ill be much happier..
First extras will for sure be a skid plate , probably from MountainTech, and possibly a OFT relocate . Does the relocate make it better/easier to steer while sitting down, trail riding etc?
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Replace the stock plastic skid plate and Go with a Mountain tech skid plate. It will save the bottom of your engine and heat exchanger from being damaged from rocks or stumps.
wavemaster
- Mar 6, 2009
- New Hampshire
- SR Viper XTX, Nytro XTX, Phazer FX
Are the relays the same? Does anyone have a part number on them?
Yannie
- Jan 5, 2014
- Winnipeg
8gn-81950-00-00
The load relay,fuel, and fan are the same. The headlight relay is different and has no updated relay.
BIG BLUE 2
- Dec 27, 2013
- 2011 FX NYTRO XTX
you should check out the thread in FAQ section on the limiter straps. This is a big problem. There are some good solutions to help with the issue.
The pic in your original post put a smile on my face. I had the same 2 sleds. Different years but same color combos. 98 700sx and an 09 xtx )
You'll see them on the HCS home page if you spend any time there. Pic below so you don't have to though
The 700 got parted out after 12k miles. But now i own that black vector int he background.
comatoast218
- Nov 11, 2014
- Superior, WI
- 2011 Nytro xtx
Haha. My sx700 has taken the beating of a lifetime. But I have replaced pretty much every weak point on this sled. Gonna miss it if it sellsThe pic in your original post put a smile on my face. I had the same 2 sleds. Different years but same color combos. 98 700sx and an 09 xtx )
