Just bought boondockers kit w/efi box for 2006 apex mtn. anyone else running the same setup? I have read clucth for 10000 and nos will jump 1100 rpm. I am looking to setup for climbing! If it works as good as everyone says I may look into just putting a 10lb. bottle on the back, hate to run out when we finally get to the KA stuff!
Also curious where guys are setting up for the auto nitrous kick in?
Not alot of posts on here lately, come on guys snow is flying some where!!!
stoutner
I would set up clutching for about 10,000 or 10,200 if you are running 50 hp nozzles. A little lower if you are running a bigger shot.
I tried to set up my TPS but it didn't work. I think I may have attached it to the wrong wire. I hooked it to the yellow wire and my throttle position on the controller only ranged from about 50 - 78 and wasnt consistant. I will check it out soon.
Once I get it working, I'm going to set it to come on about 3/4-7/8 throttle and at 9000 rpm
If your going to run a 10 lb tank, bore your nozzles out and run 70hp shot. Do you have the regulator?
