musselmark
I just installed a new 32 Talon pre studded 1.25 on my 2010 vector gt and there is a vibration felt through running boards at mid speed but goes away at higher speed. All bearings are good or new, new slides, all bogie wheels are good with new bearings, clutches were dealer serviced before this track swap and there was no vibration then, belt only has few hundred km and was fine before swap. I put 20km on new track, do the bends from storage/shipping take time to work them selves out, will they cause vibration. Also on deceleration it feels like something is rubbing, track is pretty loose, ( when in the air I can pull track down 2+") would too loose cause rubbing on front heat exchanger protectors while engine braking? I disconnected transfer rod to reinstall skid, is there any chance something got flipped around and is not right in skid? what else can I check? Thanks
