Paraclete
I have no idea what you call it but it the little button type thing under the shroud that the side panels hook on to.
There is not one on the righthand side and was wondering if there was an easy way to repair it.
Th side panel is a bit loose and the previous owner decided to screw the plastic right by the reverse handle
![Banghead :o| :o|](/styles/default/xenforo/smilies/banghead.gif)
YammyRX1
Not sure if this is what you are talking about:
Paraclete
If you look at te ignition switch just to the right of it and under the same panel should be a little plactic post the side panel hooks to. I will take a pic later today
apex55
I think he is talking about the knobs that are molded on the inside of the instrument panel.
My guess is you don't have the missing part.
You may be able to fabricate it by using a screw from the outside secured by a nut on the inside with the screw sticking out of the nut. It should give enough to hook onto. Look at the other side, maybe a small cabinet knob or fabricate something out of wood to screw thru.
Paraclete
Here are some pics.
What it is is the little piece of plastic under the gas tank cover that the right hand side panel hooks on to.
If you look at this pic you can see on the righthand edge a 1/4" circle
On the underside this is a pic of the same thing on the left side
![](/styles/TYLifeMember.gif)
![](/styles/vip.gif)
Soldier'spapa
- Mar 21, 2006
- Naperville, IL
- 2018 Sidewinder Ltx LE 50th Anniversary
I think I would try fabricating {carving with a Dremmel) the catch post from plastic or poly and adhering it to the inside spot. I likely would try Gorilla glue for this job, but there may be better adhesives.
Beats drilling and bolting something.
Paraclete
I eneded up buying J-B weld and a T-nut.
I glued the T nut on upside down and it worked great. I did have to reduce the height with a Dremel.
![0,0,463,20201,859,604,8cbca537.jpg](/proxy.php?image=http%3A%2F%2Fimg.en.china.cn%2F0%2F0%2C0%2C463%2C20201%2C859%2C604%2C8cbca537.jpg&hash=07bf3dee3c23344db62b3849987aaad3)
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
good idea let us know how it holds up
Paraclete
I got lucky really I went to the harware store just trying to find anything. These things are almost perfect. I will let you know how it holds up, (If we get any snow)
Soldier'spapa
- Mar 21, 2006
- Naperville, IL
Nice fix!
I would hate to have seen something through bolted.
Hope it hold up!!![Div20 ;)! ;)!](/styles/default/xenforo/smilies/div20.gif)
Hope it hold up!!
