No top end
what are the rpms at?
when was clutch's last cleaned?
You need to get the clutch calibration straightened out! It should be running 10,200-10,500 rpm's at full throttle!
Another thing to check is that ALL 4 rubber boots are seated fully and properly over your carbs. Easiest way to check is take the lid off the airbox and feel inside the throats.
