John Elie
- Mar 5, 2015
- 2003 RX1
So, my 03 rx1 was running fine last week. This week won't start, no click, nothing. Battery is fine, all small fuses good and main fuse on solenoid good. If I put a screwdriver across the solenoid, it turns over perfect. I replaced the solenoid with a new Yamaha unit and same thing won't start. Any thoughts?
Does the dash light up?So, my 03 rx1 was running fine last week. This week won't start, no click, nothing. Battery is fine, all small fuses good and main fuse on solenoid good. If I put a screwdriver across the solenoid, it turns over perfect. I replaced the solenoid with a new Yamaha unit and same thing won't start. Any thoughts?
The plug for the keyswitch is a good place to start. Unplug it and visually inspect.
RAMSOMAIR
Starter might be pooched
John Elie
- Mar 5, 2015
- 2003 RX1
I don't remember the lights every coming on with key on, but no, no lights. Starter is fine because when I jump the solenoid it's turns over fine
Stubbs
- Nov 7, 2006
- Uxbridge, On, Can.
+ other gooodies
- Uxbridge ON
Did you purchase an OE solenoid or aftermarket? Are you sure it’s the correct part? The RS sleds have a solenoid/relay that looks identical, but isn’t.
He said Yamaha but u may be on to something about the wrong one.Did you purchase an OE solenoid or aftermarket? Are you sure it’s the correct part? The RS sleds have a solenoid/relay that looks identical, but isn’t.
Before you changed the solenoid was it clicking?I don't remember the lights every coming on with key on, but no, no lights. Starter is fine because when I jump the solenoid it's turns over fine
John Elie
- Mar 5, 2015
- 2003 RX1
It was a yamaha part, no clicking, nothing
Stubbs
- Nov 7, 2006
+ other gooodies
- Uxbridge ON
John Elie
- Mar 5, 2015
- 2003 RX1
Ended up pulling each wire out of plug for solenoid to inspect. One wire had corrosion on it, cleaned and greased it now is fine. Unbelievable, cost me $100, oh well live and learn. Thanks everyone for you feedback
It's a good idea to replace the solenoid anyway.
