givemeaboost
- Dec 5, 2003
- Great Falls, MT.
- 03 Rx1 Turbo
- Great Falls,MT
Does anyone know what I need to do to hook up nos for a one second shot out of the hole. I need something for a better hole shot and was thinking of hooking one nozzle into the charge tube to the intercooler and have it soot just long enough for the boost to come up. Would I need extra fuel for a quick shot like this ? There will be extra fuel as soon as the boost comes on but don't know how to set it up to come on with the nos.
- Apr 14, 2003
- Hessel, Michigan
I think you would be able to just shoot a dry system to get the turbo to spool quicker. Some have used a controller that turns off the nitrous when boost is acheived. Could use the wet system also.
Blown14psi
Definitely spray wet in the turbo intake. If you spray in the charge tube you'll need a high pressure EFI fuel pump to provide the fuel under boost or you'll lean out the motor.
If you spray with a single wet nozzle in the turbo intake with a low pressure fuel pump you can spray all through the power band, it will cool the turbo, and it will be much easier to tune.
stoutner
- Dec 6, 2005
- Seneca Falls, NY
- www.ecsexpress.com
Yeah,
Why not spray the whole time? If you're goona go through the troble of installing Nitrous, might as well get the full benefit.
