tdog1225
I know there's threads on here but I can't find them. Hit something and now the left side is tweeked. The shock spring is almost touching the upper a arm. So I know its the lower arm. That thin plate between the left and right side has a wrinkle also. Nothing is bent on the a arms. If I remove the shock and put something between the spindle and the frame will it be able to b bent back. I will then weld a heavier plate to the underside to hold it amd beef it up. It drives fine but I need it fixed. When these bend does it kink the tube frame? Help me out please.
Yamanimal
ken0la
- Apr 13, 2007
- NWestern ON
- NONO
There is a ton of info here on the subject, keep searching, its all there...
ruttinbuck
- Jan 25, 2012
i wonder if they reinforced the sub-frames on the 2013
dont me to hi-jack just looking for options
