New member - bent subframe club!
The lower arm is bent too, you can sort of see it in the pics, it has a curve to it. I'll need to pull the spindle to see if it's any good. Even though I was going ridiculously slow it was a jarring hit and I knew there'd be damage. Not even sure how it happened, the ski must have dropped in and caught just right, the tip of the ski did NOT get caught in the hole, it made it across.
Mine is tweaked similar to that on the right side and the shock points back a bit too. I bought it like this. I'm sure if your in a pinch, just replacing the lower A arm is all you will need. It is likely what is causing the toe in, because mine is tweaked similar and the ski's look fine.
