Lssedan
- Jan 15, 2019
- Pa
- 09 Nytro xtx
I know I need to replace my skis and get the oft relocation kit. But until I do. I am stuck with stock skis my question is how much carbide is to much. I have the xtx 144” track and it is not studded. As of now I have dual 9” carbides on each ski. Back gets loose when I deceleration fast on hard pack. Would dual 4” be good? Can I just grind some carbide off??
Hooray!
- Aug 12, 2017
- Maine USA
- 2009 Yamaha FX Nytro XTX
1998 Yamaha VMAX 700 XTC
Do you have stock 2009 single runner skis or 2010+ tuner I/IIs with dual carbides? Check out the Bergstrom website, he has some great Nytro suggestions for stock 2009 or tuner skis. I went with tuner IIs and his full set up and amazing.
Lssedan
- Jan 15, 2019
- Pa
- 09 Nytro xtx
They are the stock 09 skis with stud boy or woodys dual carbides. Just seems like a lot of carbide for no studs even being the xtx model shouldn’t need that much should it??
yamahinn03
- Dec 28, 2004
- oshkosh, wi
- 18 Sidewinder (Wifes)
12 Nytro XTX (mine)
09Apex GT (?)
02 Viper (grass dragger)
6” max with no studs.
Lssedan
- Jan 15, 2019
- Pa
- 09 Nytro xtx
Ok thank you. Do you thing I can just grind them down to 6” eliminate some of the carbid I really don’t want to buy another set. They are duel carbides
tomseal6
- Aug 23, 2006
- Brevort, MI
- 4 strokes
X2 on 6 inches with no studs.
Snow trackers on mine..... 2010 nytro xtx with 1.75 backcountry track that is not studded
Lssedan
- Jan 15, 2019
- Pa
- 09 Nytro xtx
What trackers do you have semi aggressive? I’ve read that they are dangerous lol. I mainly ride in tughill and old forge so a lot of icy conditions usually.
semi aggressive--- love em.. yes I have hade them bite in the corner--- but I like the slot car feeling--
Lssedan
- Jan 15, 2019
- Pa
- 09 Nytro xtx
Ok I see some on eBay for $169. How do you set up your nytro with them? Do you run the limiter straps loose to keep weight off of front end ?
im pretty sure my limiter straps are in the stock position--I set my toe in toe out at zero when I replaces all front end bushings and ball joints and ski bushings--- When I had my attak I did pull up the limiter straps tighter by one notch but have not changed them on this nitro xtx with 1.75 backcountry track
Hooray!
- Aug 12, 2017
- Maine USA
Full Bergstrom setup has that same slot car feel w triple points, I was torn between the trackers and Berstrom, happy w decision.
