Since the Leak down tester I bought doesn't work I had to use a simple compression tester.
I have a head shim in my Nytro and it tested at 125psi across all three cylinders does this sound right??
Thanks, Wayne
Thanks, Wayne
The test was done on a cold engine without holding the throttle wide open.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
As long as Your Readings are uniform across all cylinders you're ok.
From how you did Your test you will get pretty low Readings.
Procedure is:
Warm up the engine to normal operating temps.
Disconnect fuel.
Hold the throttle wide open.
Run the compression test.
Values should be within 15% higest to lowest Reading.
Procedure is:
Disconnect fuel.
Thanks for the reply rxrider
I would usually do it the way you described but I have the sled stripped that's why I bought a leak down tester but since that didn't work I had to improvise.
Thanks, Wayne
Thanks, Wayne
