Sno-Xr
- May 3, 2005
- Clio (Flint), MI
- Nytro
Ok, some of you may have seen my posts about the electrical gremlin I chased all last year. Ive torn the sled apart more times than I can count looking for rub throughs, bad components, checked stator, swapped rectifier, disconnected suspect accessories, added extra grounds, etc etc.. without any luck.
My question now is, does it matter the year and model Nytro ECU I try if I find one to borrow to see if this eliminates my issue?
Next question would be.....who's got one to loan out?!?! LoL
Should not be an issue, they are all basically the same from what I remember, you can also cross ref part numbers in the Miro-Fiche Yamaha websites.
Sno-Xr
- May 3, 2005
- Clio (Flint), MI
- Nytro
Great, thats what I was hoping to hear. Going to look at a 2012 with decently low miles, if I get it I may swap the ECU'S to see if the issue follows the ECU. Beyond that, im at a loss.....i will at the least, have an 09 parts sled for the 2012!!! Hahaha
Thanks Tom
Thanks Tom
Thanks Tom
You can cross ref , the part numbers, should not be a problem.
