juwalantz
i have a 2009 nytro mtx. the sled started to flash an error code when i fired it up this year. its flashing code number 37. this code says the idol speed control valve is stuck open. i ran diagnostics on it and checked the idol speed vibration. everything is fine the valve operates as it should. how do i erase the code. on diagnostics code number 62 is how to erase but i could not get it to erase. i went to code 62 and pressed the grip side of the grip/thumb warmer button but it nothing happens. am i doing this correctly
juwalantz
ok a little update. i cant get the code erased because it has not been corrected. the sled idles at 2500 rpm. isc valve is stuck open.
