char45lier
Does anyone know if a Nytro gauge cluster is compatible (will plug in and work on) an Apex?
why would you want that on your apex?anyways< i have no idea?
yamaouch08
- Jan 17, 2006
- Otisville,Michigan
- www.chapmanssports.com
Why??? The Apex one is much nicer!
Daranello
Suspended
Ill trade ya my low millage Nytro Clustor for your Apex cluster!!!
LazyTiger08
That would not work would it? I thought the ECU kept the mileage...
Daranello
Suspended
I understand its the cluster and not the ECU
LazyTiger08 said:That would not work would it? I thought the ECU kept the mileage...
99srx600
yea mileage is stored on the cluster.
char45lier
The reason I ask is because I have a Nytro cluster and an Apex motor. I'm trying to save $400 if I can.
Daranello
Suspended
Ya should, but I sure youl have to re wire...some guys are using Apex clusters on Nytros and with minor mods it works
nate007
- Dec 25, 2006
- Iowa City, Iowa
- 1. '06 Apex -twin screw
2. '04 Redline Revolt 800
3. '09 Nytro XTX - twin screw
There's the exact opposite thread in the Nytro section, with a pic of somebodys installation. it looks like it works, but the tach pulsess are different between the 4cyl and 3cyl motors. I know you can get tach pulse adapters from companies like MSD, etc. Just be prepared to make some modifications.
- 8K
