If there is not coolant activly leaking out while the sled is sitting and its not leaking when it is running and idling it seems like it is likely just drainage from the overflow due to the sled getting warm. If the coolant level is where it should be then it is safe to ride, just monitor and frequently check it for a while to make sure the level stays where it should and there are no fresh signs of leaking.
Let it idle up to full temp, until the the rad fan comes on too.
You'll want fluid pumping through every part of the system...
If you don't see anything, go for another shakedown ride.
