skidoots
hey guys need some help. just got a new used nytro 08. started it the other day and gas was running out of the belly pan on the right hand side by the foot rail???? it runs fine as far as i can tell .
lucky_7
Maybe it was too full? Some say that it shouldn't be filled above the neck of the white thingy inside.
srxpert
gas
possible the fuel return line came off the tank.sled would run fine but leak gas all over.had this happen on my apex gt.shane
LazyBastard
You really can't ask anyone where the fuel is leaking unless you show them the sled. There's no way to know as a leak could be anywhere on the fuel system. The only way you're going to find out where its coming from is by actually following the gas leak in reverse until you find its origin.
08NitroRTX
There's a return fuel line on the FX Nytros?
I'd guess it was filled too full as the vent tube is not at the very top of the fuel tank. Sitting on the seat of a topped off tank will cause fuel to spill out the vent. If this was winter and temps colder we might assume thermal expansion raising the fuel level and causing the same effect.
apex yooper
I would very much doubt that filling the tank too full is the problem. if it's not, take it back to the dealer.
