Nytro meth injection pics anyone?
347strokin
Cold Lake, AB, Canada
Hey guys,
I purchased a meth injection kit from Hurricane, thanks Dave!
I haven't got it yet but I would like to see some pics of how everyone is mounting their gear on a Nytro.
Example: resevoir, pump, spray nozzles, where you are getting your boost pressure from.
It's definitely a little tight on these sleds. Thanks.
Here's my main problem, I don't know where to mount my spray nozzles on the intercooler because my blow off valve is kind of in the way.
The picture is showing the front of the intercooler and the throttle body boots. The one boot is hidden by the steering linkage.
The nozzles should be mounted perpendicular to the air flow, not straight on at the throttle bodies. Try the top of your plenum?
For a minute there I read the title of this post as "Nitro-Meth Injection".
did you get this mounted?
Thanks,
Eric
No I haven't recieved the kit yet but very soon.
Dave has recommended for my application to run the nozzles from the bottom of the intercooler as my blow off valve is in the way on the front.. He has also said it is more beneficial to run the nozzles directly into the throttle bodies if you can.
