snowmaaan
- Sep 7, 2005
- Fairmont, MN
- Yamaha Sidewinder, Viper XTX Turbo, Apex SE, Vmax 4, SRX 700
- Farimont MN
Not sure if my AF gauge is wired improperly but I keep getting the NEW AEM air fuel gauge reading dash marks...
Seems somewhat stable at lower RPMs but higher it turns to dash's
I have a 09 XTX with a stage one MPI kit running 5lbs of boost at sea level on 92 octane...anyone have a clue what my fuel setting should be as a base line?
Also, where do the rest of you guys wire the power in for a the AF guage.
Thanks!
Thanks!
Agman 57
- Dec 28, 2006
- Fostoria, Ohio
- 2018 Apex XTX LE, 50th Ann.
2018 Sidewinder LTX LE, 50th Ann.
2017 Sidewinder BTX LE
1992 V-Max 4 (Modded)
2002 ZR 120 G-daughter's
What kind of gauge are you using? A pro-logger or just a standalone gauge? And are you running the GEMS unit for the fuel controller? Need to know what you are working with.
snowmaaan
- Sep 7, 2005
- Fairmont, MN
- Farimont MN
I have the supplied Fuel Controller (GEMS i believe) and a New AEM Wideband gauge...stand alone.
I rode it tonight and it seems ok and then it starts reading funny..and eventually goes to dashes (lean...). I think its a ground issue...pwr source issue or a bad gauge.
Thougths? Again, if you could share the proper pwr source location that would be helfpul!!
SRXSRULE
When it goes to dashes its "over limit". That means its out of the range of what the gauge can read. That means its VERY lean, and close to miss-firing or is doing a lean miss/pop.
You can take the power and ground right from the D/C power outlet on the dash. Eric
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Where are you drawing power from for the gauge? Is it from the red/white wire by the key switch? If so that will cause the gauge to go to "---" on it.
Rx-377
Srxspec said:Where are you drawing power from for the gauge? Is it from the red/white wire by the key switch? If so that will cause the gauge to go to "---" on it.
x2 Had the same thing happen to me.
snowmaaan
- Sep 7, 2005
- Fairmont, MN
- Farimont MN
Thanks for all the input. I noticed the ground wire is very small...replacing that. I will check the wire color tonight that I am drawing from...where do you guys suggest we tap into power at (color/location,etc. would be great!)
My first ride yesterday...thing is flat out fun to ride with the MPI kit on it!! WOW!
Ratpack
- Oct 11, 2006
- Frewsburg NY
- 2003 RX1
Wait until you go with more. I once heard that boost is addictive. IT IS.
machz69
Why would it do that? and where should it be drawn from?Srxspec said:Where are you drawing power from for the gauge? Is it from the red/white wire by the key switch? If so that will cause the gauge to go to "---" on it.
snowmaaan
- Sep 7, 2005
- Fairmont, MN
- Farimont MN
Thanks Allen...spoke to Allen and he suggested the wire loom on the clutch side (red with yellow stripes) in a harness that go nowhere...apparantly the switch is not stable pwr.
Thanks!!
Thanks!!
