rideblue
- Mar 17, 2005
- Buena Vista Colorado
- www.mountaintechbv.com
I will have a Nytro MTX at my shop Monday and Tuesday, March 19 and 20. If anyone in the area would like to check it out, let me know what day or time. Normally closed on monday, but will open up if enough people will come.
Also going to try to get a digital hanging scale and find out what wet weight is. Sled looks like it is closer to what production sled may be.
Have it at my house now, and there are some changes over the one from the dealer and consumer show in Denver. Just what I can see at a quick glance.
1. handelbars and riser
2. tunnel braces
3. rear drop brackets
2. tunnel braces
Bodacious
Could you measure the center to center distance on the front ski shocks(fully extended and compressed). Interested to know my Fox floats from the Attak will bolt up or are they shorter or longer? Thanks
Vmax4
- Apr 18, 2003
- Orondo, WA
- 2010 FXNytro MTX 162 SE with a 270 hp MCX Turbo and assorted goodies!
Yeah, I would be interested to know if the Phazer GYTR Clickers would bolt on the FX Nytro MTX. I like the Nitro MTX, but think the shock packages are kinda lame. Would like to have the same high quality stuff as the RTX with the longer track.
Thanks,
Steve
Thanks,
Steve
Mtnviper
- Aug 19, 2003
- Burlington Wa.
- fourstrokesolutionsllc.com
rideblue, I'd be real interested in true wet weight of the sled. Since it has some of the add-on's that alot of guys like to put on.
errol
- May 24, 2003
- Quebec, QC
- 2018 SW B-TX LE 50th
Please take a pictures of the WET weight and the amount of gas in it, if not full !!!!
Thanks!
Thanks!
rideblue
- Mar 17, 2005
The Nytro MTX weighed 564 out of the crate and 608 full of gas. The only liquid that is missing is the electrolite for the battery, add 2 lbs for that. It is a non-reverse MTX. This was 18 lbs lighter than our MCXpress mountain lite and 83 lbs lighter than the vector se. All sleds were as full of gas as we could get and all fluids were checked and topped off as needed.
i will post pix when i get home tonight.
DITCHBANGER
i thought reverse was standard on the mtx?
rideblue
- Mar 17, 2005
Here are pix from the Nytro MTX weight. I am happy that the wet weight is that close to 600. Would be nice to see it under 600 out of the box. A simple battery swap would do that though.
Final spec production weights may vary from these some.
The blue mtx come with or without rev.
Sorry, I did not have time to measure shock length.
Wish i could get some 2 stroke guys to put their stuff on a scale wet! They all seem to gravitate to dry weight cuz it sounds lighter.
Mtnviper
- Aug 19, 2003
- Burlington Wa.
Thanks rideblue, hopefully the production units will weight the same (or lighter would be cool). Good to see that it is that close to 600 lbs. Like you, I was hoping to see it 600lbs or slightly below.
Shave 40 lbs off of it with some aftermarket stuff, and your right there, or even lighter then most 2 strokes!
sledskiing
- Oct 18, 2006
- Lakewood, CO
- www.sledmods.com
What do you guys think a boosted Nytro will weigh in at.
MC Xpress Turbo
162 x 16 track
Add 20 lbs?
Looks like I can get my boosted Apex within 45 lbs of a boosted nytro with extended track.
MC Xpress Turbo
162 x 16 track
Add 20 lbs?
Bodacious
I spent a couple of hours tonight checking out the Nytro MTX at the Traverse City Show. This thing looks pretty well built, the a-arms are completly different then the Apex's... so it looks like the bushings wearing out early may not be a factor on this chassis. With the left side panel removed I could easily get my hands on the spark plugs, also the anti-freeze overflow bottle is easily accessable in the nose area. To me this chassis looks to be much, much , much easier to pull maintainence because everything is more accessable. This alone is a major "PLUS" in my book. Pretty cool sled, this may be my ride for 08', but in the Anniversary colors for sure! Oh yea, sure wish that there was more storage area, looks to be only a bag in the nosecone void. The total length from ski tip to the rear bumper measures 129". Also the front shocks fully extended with front end hanging measure. Hyfax measures near or at 60", with 6 idler wheels in the skid.
DITCHBANGER
on the canadian website reverse is standard on the mtx or the 40th version..610 wet is fine in my books,add es to a 07 summit 800 and its 600lbs wet..ill be doing an exhaust,battery and front end..so possibly taking 20-30 lbs off..
ou812
Wish i could get some 2 stroke guys to put their stuff on a scale wet! They all seem to gravitate to dry weight cuz it sounds lighter.[/quote]
not here to bash ive been gathering info as im going to buy one of the 08 nytros.would like to know what the easy way to get weight off is. my 07 800 2 stroke is 564 pounds wet with tools, spare belt, day pack with shovel, and belly pan protector. light weight can is only mod, i also have a calibrated scale in my garage. do you think 550 wet is possible with the nytro with a lot of titanium parts. would also know if any of you have relocated your battery to the rear of the machine, to get some of the weight off of the front
Phazed-Coug
If the exhaust weighs anything like the phazer(which I'm sure its more) you can loose 15lbs real fast..
the phazer exhaust I think is around 20lbs... (don't have a scale but its in my truck)
rideblue
- Mar 17, 2005
The sled I weighed didnt come with reverse and has a full VIN on the tunnel. Yamaha has not told us that the mtx will come only with reverse. Dont think yamaha would ship a unit to my district manager if it was not correct. For now i am assuming the mtx w/o reverse is in the lineup untill i hear otherwise.
There is going to be at least 30 easy lbs or so to loose between exhaust and battery. The battery is mounted above the chain case so the weight is not out in front of the engine like the rx, apex and vector.
Seat seems fairly light, so not too much there. Not much weight in the hood or headlight either.
550 might be doable with the right parts and enough $?
Yamaha did a great job on this sled!
- 68K
