Dan Lance
- Mar 5, 2019
- Eagle River Ak
- nytro,apex,summit,rs vneture,phazer
Hello all. Running a PCV-PTI with Autotune on my boosted Nytro. Is there any benefit to adding another baro/map sensor to the 0-5v analog input for baro/air density changes? Does the stock Nytro baro constantly adjust for elevation/baro changes or does it take a sample on start up and run off of that until started again? I would think the factory system would compensate. Also would the autotune make required correction anyway based on what it sees coming out? Don’t want to over think it, but if there’s gains in drive ability then I’d like to do it.
