rbell14
Need to adjj rear shock, is comp adj. The screw on bottom leftside of shock? I see a second screw on top side of the rear shockoil resevoir, is that the rebound adj??[/u]
shelby99
- Jan 24, 2010
- St.John's NL
- 2009 FX Nytro RTX...
Check out the sticky section on suspension setup. Loads of get information in there.
rbell14
I've combed the FAQ and obtained a lot of tips on set up but what I can't find is which adjustment is the compression and which is the rebound?
dansranger
You can find the explanation in the owners manual.
In short the rebound is on top of the shock and the low speed compression is the screw.
