rrxx-1
Rear Shock
Fast Comp clicks out 4
Slow Comp clicks out 5
Rebound clicks out
I have a 08 RTX, are there fast and slow comp adjustments on the rear shock? I can only find comp and rebound. I see in the setup thread some guys with 08 stating their setup with fast and slow comp settings(see above). Thanks...............
Rebound clicks out
rrxx-1
Help.................
gormleyflyer2002
08 RTX has slow speed comp adjustment only on both rear shocks........no high speed. And rebound of course.
some guys....................!!!! who knows. Maybe they have 09's
stewartb
From what I can tell the RTX-SE is the only model with a triple clicker on the rear arm. Hygear can convert double clickers to triple clickers according to their web page. FWIW, all 4 of my Ohlins are triple clickers.
From the Ohlins manual...
SB
A simplified description
Low speed circuit: More damping will make the
ride firmer and higher.
High speed circuit: More damping gives a firmer
ride and more resistance against bottoming
SB
rrxx-1
Thanks guys. I thought I was going nuts.
