Foxhead
Does anyone have the literature or document or know off hand the stock hole position for the front limiter strap on an '09 rtx se? Anybody have better results with a different position?
Pstn head
Mine is a 10 rtx should be the same factory set up which was the first hole ( longest length) I tried the 2nd and 3rd hole I find the 3rd to be better
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
That is correct, the first hole or when the strap is the longest is the stock location. If you keep tightening the strap it will cause more ski pressure/less ski lift/less transfer.
Foxhead
thanks guys, find out info quicker here than trying to find it elsewere.....love this forum!
