yukonranger
Does anyone know if the nytro secondary will fit and hopefully line up on a phazer?
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
No it will not. You need a secondary off of a 1995-1996 Yamaha Vmax model sled.
The 95 vmax 600 secondary uses the same helix that you have now but they use teflon coated bushings. Iam using it on my phazer. I have a 96 reverse secondary off my 600vmax it will fit but you would have to move the engine over to get the correct offset. I tried and not worth the time
Otter
Otter
yukonranger
Thanks for the replies guys. The reason that i want to go to a different secondary is so i can run a shockwave helix for better tunability. That and the phazer secondary is in pretty rough shape after only 2 seasons.
- 8K
