honda400ex2
- Apr 11, 2014
- Rice, Minnesota
- 2014 Viper XTX
I bought a set of Curve Ski's and want to relign the ski's. Was told to run 1/8" toe out per ski 1/4" total. Also was told due to the Nytro handling could go up to 1/2" total. What have others been running?
Also some sites and videos say use a light bungie on the ski loops to remove the light slop. Was thinking, wouldn't it be better to bungie the rear of the ski for adjustments; then it would pull the front of the ski's into their natural tracking habits like it does when the machine is moving. Or do the ski's naturally pull toe in when moving.
sxvipersman
- Mar 19, 2006
- Dover Centre,ON Canada
- 2008 FX Nytro RTX Anniversary Edition
1979 Enticer 340
2009 FX Nytro XTX
I'm running curves on my nytro with Bergstrom triple points at about 3/8" toe out. Tracks good that way. Also have the skis shimmed to put pressure on the heal of the ski. Help tracking. Lots of write-ups about shimming the rubber on the ski. Pretty sure mine are shimmed about 1/4" at the rear of the rubber.
Hooray!
- Aug 12, 2017
- Maine USA
- 2009 Yamaha FX Nytro XTX
1998 Yamaha VMAX 700 XTC
I have the same Bergstrom triple points and rubbers reversed and shimmed and their ski savers (3/8" spacer under carbide). Works perfect on my Tuner IIs, I think they have a good system regardless of the ski.I'm running curves on my nytro with Bergstrom triple points at about 3/8" toe out. Tracks good that way. Also have the skis shimmed to put pressure on the heal of the ski. Help tracking. Lots of write-ups about shimming the rubber on the ski. Pretty sure mine are shimmed about 1/4" at the rear of the rubber.
honda400ex2
- Apr 11, 2014
- Rice, Minnesota
- 2014 Viper XTX
Thank you both for the info. It sounds like Bergstrom triple points are a great product. I did shim mine also at 1/4, and it does seem to help with the darting and a more even wear of the carbides, as mine were wearing in the front before.
sxvipersman-- You said you were running about 3/8 toe out? Is that per ski or total?
Hooray!--The 3/8'' ski savers under your carbides, is it noticeable for handling (easier or harder turning) or about the same?
sxvipersman
- Mar 19, 2006
1979 Enticer 340
2009 FX Nytro XTX
3/8" totalThank you both for the info. It sounds like Bergstrom triple points are a great product. I did shim mine also at 1/4, and it does seem to help with the darting and a more even wear of the carbides, as mine were wearing in the front before.
honda400ex2
- Apr 11, 2014
- Rice, Minnesota
- 2014 Viper XTX
3/8" total, thanks for the help.
dstrikerd
I'm running curves on my 08 Nytro rtx with 6" shaper bars. i have my skis at 1/2" toe out.
Dustin
Dustin
herndonp
- Nov 28, 2012
- Freedom,NH
- 2012 Yamaha Nytro XTX
2012 XTX with curves toe out set at 1/2"
Pete
Pete
Hooray!
- Aug 12, 2017
- Maine USA
Yes, when you add to carbide depth, it does make a difference. Seems to dig in better on entry and exits.Thank you both for the info. It sounds like Bergstrom triple points are a great product. I did shim mine also at 1/4, and it does seem to help with the darting and a more even wear of the carbides, as mine were wearing in the front before.
Hooray!
- Aug 12, 2017
- Maine USA
Bergstrom has a full spec on toe out w their kit. Less than I expected, will confirm but my skis measured 3/16" to total so divide by 2 and very little per ski. Will post their instructions.Thank you both for the info. It sounds like Bergstrom triple points are a great product. I did shim mine also at 1/4, and it does seem to help with the darting and a more even wear of the carbides, as mine were wearing in the front before.
honda400ex2
- Apr 11, 2014
- Rice, Minnesota
- 2014 Viper XTX
Thanks for all the help, this gives me a better idea of where to begin.
