sledhead_dan
Thinking of putting nytro 153 skid on a 04 Rx1 mtn. How much difference in weight an handling ?
Jonny Rocket
- Colville, Washington
- 2008 MXC boosted Nitro
You will want to do some measurments before doing this. We put an AC skid in a Nytro the other day and the offset was about 2" different than the RX. Ex. On my RX-1 the same skid was set back 1". Had to go back 3" on the Nytro to fit the same skid and track. So you might not fit a 153" track in the RX if you put the 153" skid in unless you move the skid forward.
Don't about the width measurements but when we measured they seemed to be pretty close if not exactly the same.
I would think you would want to measure the center to center between the front and rear mounts just to make sure they are the same. Otherwise you will need to make adjustments for that also.
Just my .02.
J.
Just my .02.
J.
sledhead_dan
What track did you have on the Rx ? If you had a 151 on the Rx and 153 on the Nytro I can see why the skid was 2 " back. I was plannig to use the 151 with the Nytro skid.
Jonny Rocket
sledhead_dan said:What track did you have on the Rx ? If you had a 151 on the Rx and 153 on the Nytro I can see why the skid was 2 " back. I was plannig to use the 151 with the Nytro skid.
I had a 162" track on a 151" AC skid but that's not the point.
Point being I took the exact same track and skid from my RX and put it under the Nytro. I had the 151" skid set back 1" from the stock location on the RX to make the 162" track fit perfectly. On the Nytro we had to set the 151" skid 3" back from the stock location to fit the same 162" track.
Hope that clears things up.
Good luck with the install,
J.
Snobeel
The modification that I did this year was to put an apex tunnel and skid on my o4 rx. Other than a lot of rivets it was a piece of cake. The apex skid and the nytro skid are identical except for the rails. Now Im not sure the front to back mounting points are the same, but the actual suspension parts all cross reference. I found a takeoff tunnel for $150+shipping and a used skid for $300 shipped. What an improvement over the 04 skid and the best part was that all the rivet holes lined up and the skid just bolted right in no figuring required....simple.
Jack
Jack
sledhead_dan
Thanks for the info guys. I think I am going to grab the nytro skid and install. Tipped up rails should be nice on trails and will save a few lbs.
rideblue
sledhead_dan said:Thanks for the info guys. I think I am going to grab the nytro skid and install. Tipped up rails should be nice on trails and will save a few lbs.
The Nytro skid will work great but you may need to put the Apex rear springs on. The Nytro springs are only 1100 KG and will be too soft for the weight of the RX. Apex's are 1500 kg.
doo_man
sledhead_dan
doo_man did you use stock holes or make new for the nytro skid, if yes where from stock are they ? looks like a s/c oil tank , how do you like the super ?? I'm having grief with throttle not going back to idle, (3rd cable ) goes to stutter mode or sticks open. Also noticed @ 5lbs boost 15 psi fuel , 10lbs boost 18 to 20psi fuel. is that normal 5.5 psi at idle. Mpi will not return my email or posts
doo_man
I don't have the sled anymore, but I had a Apex tunnel close by to use as a template. But I think it was approx 6" back from the front mount. No gauges as well, but ran strong and was a blast to ride! I used stock Apex Mtn rear brackets too, and they are contoured to fit rear muffler bracket so it was easy to set up!
Fro-1
- Mar 2, 2009
- Labrador, Canada
- 1982 Bravo (red)
1984 Bravo (blue)
1989 Sno Scoot (red)
1989 Sno Scoot (blue)
1995 Vmax 500 (black)
1995 Vmax-4 ST (black)
2003 Rx-1 Mtn (black)
2016 VK Pro
2016 Venture TF
- Happy Valley - Goose Bay
- YOUTUBE
- Mokami
Installing a 153" Nitro track on a Rx1 Mtn Suspension
Anyone familiar with a kit that will allow me to put a Nitro track on a 2003 Rx1 mountian stock suspension? I know the drive sprockets have to be a different pitch but I'm quite sure my rear track adjustment bolts will componsate for the extra 2" length. Any ideas what else I will need or has anyone done this? Thanks.
sledhead_dan
If you do not have enough adj in track tension buy an offset axle kit. Allows you to keep 151 susp. and run 153 track.
Fro-1
- Mar 2, 2009
- Labrador, Canada
- 1982 Bravo (red)
1984 Bravo (blue)
2016 VK Pro
2016 Venture TF
- YOUTUBE
- Mokami
Offset axle kit? Thanks alot, never even heard of those. Any idea where to buy them from? And for the record, if anyone else is attempting this change out, I've just learned that I do indeed have to change my Rx-1 Drive Sprockets to Nitro Sprockets......it's a difference from having 9 teeth to 7.
sledhead_dan
My Yamaha dealer in Peace River told me about them. I bought a 08 nitro susp. with a big wheel offset axle kit on snowest. Installed the 153 susp in my rx1 , rotated the axle forward to run the 151 track in the 153 susp. If I rotate it back I should be able to run a 156
Fro-1
- Mar 2, 2009
- Labrador, Canada
- 1982 Bravo (red)
1984 Bravo (blue)
2016 VK Pro
2016 Venture TF
- YOUTUBE
- Mokami
Well I thought my problems were going to be solved with Nitro Drive Sprockets installed on my Rx1 but now I am waiting to hear back from the dealer because apparently Yamaha changes the're Hex Shaft sizes from time to time and 2008 Nitro Sprockets may be 1" 7/8 in the centre. I'm willing to bet my next question for the dealer is going to be "will a Nitro shaft fit my 03 Rx1?" either way, so far putting a 153" Nitro Track on an Rx1 isn't simple by any means and may not be possible.
