nytro skis
Battersea ontario
I just bought a set of sly dogs I removed the stock skis but i can't seem to get the factory bushing out of the spindle any tricks or does anyone know if i can just use the factory bushing i installed the new skis and it looks ok but i just want to be sure.
You should be fine, if they mount up you're good to go. My c&a's, and simmons use the stock spindle bushing also.Come to think of it I don't recall any skis I've had requiring a different spindle bushing. Enjoy the better handling.
Easier if the front end is sitting on the ground to compress the rubber. Much easier to get the bolt in.
yep, slydog skis use the stock bushings, bent one of mine and a stock replacement was the exact same size.
