LeeKo
scott32 said:There is a front hole and a back hole located on your lower arm. For the stiffer position install into the front hole. The front hole is the one nearest the front of the sled. No need for pics as this is not difficult to explain or figure out. You need to do this to both sides. You are creating less hinge in the joint making it stiffer. Poor design really, but this is all we have to work with so far.
Yamaha has the worst design out there. All the other manufactures have inboard stabilizer bars that don't hang down below the a-arms. It looks like a n accident waiting to happen to me. I wish they would change it or someone would come up with one from the after-market.
scott32
- Jan 12, 2009
- huron county, ontario
- 07 Apex RTX se, 09 Nytro XTX
LeeKo said:scott32 said:There is a front hole and a back hole located on your lower arm. For the stiffer position install into the front hole. The front hole is the one nearest the front of the sled. No need for pics as this is not difficult to explain or figure out. You need to do this to both sides. You are creating less hinge in the joint making it stiffer. Poor design really, but this is all we have to work with so far.
I couldn't agree more.
SledderSteve
- Apr 23, 2003
- Orange County California
- Rental
These guys make an awesome swaybar for the Phazer: http://www.schmidtbrosmotorsports.com/Y ... r-Kit.html
Might want to give them a call to discuss adapting it or something like it to your Nytro.
2008 Nytro RTX
for 600 bucks ill adjust my stock one
nytro addict
Man thats quite an EYE SORE. I'll stick with stock also.
2008 Nytro RTX
hahaha,1st thing came too my mind is MAN THAT IS UGLY
nytro addict
When you guy adjusted your sway bars. Did you have to lift the sled up? Is there alot or any tension when you discontted the sway bar? Any tips before I start wrenching and try this would be great. Thanks
2008 Nytro RTX
I have no idea,I still have too
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
I didn't raise the sled up, just did it on the ground, no tension.
billymx815
- Nov 17, 2009
- S. Berwick, Maine
- SXV Venom, RTX Nytro, SR Viper RTX SE
- Maine
Grimm said:I didn't raise the sled up, just did it on the ground, no tension.
X2
nytro addict
Hmm thats odd i'd think there would be some kinda tension on the bar.
Thanks for the info
Now I have to change it and give it a try.
Thanks for the info
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
SledderSteve said:These guys make an awesome swaybar for the Phazer: http://www.schmidtbrosmotorsports.com/Y ... r-Kit.html
ya I talked to him about one for the nytro...didnt seem ready yet...those daggers pretty intimidating....a little longer and they could double as skewers for shish kabob...only problem is you'd have to cut the stock bar off....
toddt
My lower a arm only has 1 hole for the link to sway bar, am i missing something, LOL.
I guess i can drill another hole closer to the front ???
sgilbert
proofs in the pudding, so I'll try it, but looked it over really good last time we discussed this and I dont see swapping holes having any effect. the whole is same distance from frame and sway link has a tie rod that makes the whole swap ineffective. the new whole would have to be closer to the ski to have effect
c'mon arteex, get your slide ruller and protractor out and settle this.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
sgilbert said:proofs in the pudding, so I'll try it, but looked it over really good last time we discussed this and I dont see swapping holes having any effect. the whole is same distance from frame and sway link has a tie rod that makes the whole swap ineffective. the new whole would have to be closer to the ski to have effect
then dont do it..
if youre happy stick with what you have...
who knows maybe all the things Ive done to my sled are just the placebo affect...uh not!
