Nytro Stabilizer bar adjustment
listen buddy, not knocking it. looking for more sway bar action and very interested. would just like to see the logic in it. what good are these ideas and this forum if not to discuss them. either way, I will try swapping on trailside, easy and nothing to loose
toddt said:
My lower a arm only has 1 hole for the link to sway bar, am i missing something, LOL.
I guess i can drill another hole closer to the front ???
Maybe the 08s don't have 2 holes up front?
sway bar
You can always flip your sway bar around and run it in between the a arms. You just have to make up your own dog bones to connect sway bar to a arm. will also have to weld a brace to run a bolt through to hold your dog bones in place on the lower a arm. was a day project.
if ya have to worry about skilift on a trail then your prob going over taril speed limit.
If you're going under the trail speed limit why would you buy a 135HP Nytro? The stock Nytro is capable of horrific handling and ski lift under 15 MPH. Don't change your riding style because your sled can't handle it. CHANGE YOUR SLED
hmmm got mine so i could get off the trail. liked my old vector for the trail it was sweet
