thanks for the info.If fuel pump is working you will hear it. As long as there’s no major noise going on around you. Fuel pump mite run about 3-5 seconds till it’s primed up you could say . Then it will stop.
( that’s with key turned to on but not the start position. )
If you don’t hear pump kick in try and wiggling the big green maxi fuse beside the starter solenoid ( starter relay) bad connection corroded.( that’s where my problem was last week)
i've checked fuses, harnesses, etc. no amount of wiggling seems to help.
with juice getting to the fuel pump and no noise or fuel pumping out the line, i think i gotta spring for a fuel pump. do i dare a used one off ebay? any recommended parts suppliers online?
