sledder454
I have done a bunch of searchs and cant find what im looking for. So my question is I have 2009 xtx qnd my track has been rubbing pretty good on the lower shock mount and wore it out quiet a bit. looking to upgrade the shock to something different what shocks are out there that will replace the factory front skid shock
Snowman871
- Feb 9, 2010
- Woodville, WI
- 2024 Polaris Assault 850
Subscribed
sledder454
what do you mean by that?Subscribed
sledder454
I have found a center shock off a 2007 nytro on ebay. they look identical and the measurements are that same also from eye to eye. the part numbers are off by just a couple letters could this be just different valving between the two shocks.
2007 nytro center shock 8GF-47481-00-00
2009 nytro xtx center shock 8HL-47481-00-00
bitburner
- Sep 10, 2014
- 2013 Nytro XTX 1.75
I think that shock would be off the original nytro that was based off the vector chassis it was a 121" skid. I don't think it will work for you. The xtx skid isn't a mono shock either. If you search fox zero pros for the nytro you might find something.
sloan188
- Nov 28, 2012
- Vaudreuil, QC
- 2005 Polaris Fusion 900
2009 Nytro XTX
2010 Ski Doo GSX LE 1200
The site is "booby trapped". All you need to do is post to a thread and you are automatically subscribed to it meaning you get email notifications when new posts are available.what do you mean by that?
sledder454
ya ive looked for the fox zeros only found them for the rtx and have found nothing for the xtx
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
Call Pioneer Performance, Hygear or Chris Schmidt at Schmidt Bros. I would think one of them could give recommendations.
stubb111
- Feb 4, 2012
- Ottawa area
- 2009 nytro xtx
fox zero pros, exit, custom axis, ohlins, have shocks available for your xtx...... I went through the research a while back when deciding what to do with my 2009 xtx
Nytros rule
- Jan 30, 2011
- Rider Nation
- 2014 Black Viper XTX
I did the Schmidt Bros upgrade, respring, revalve and it worked great. Improved handling and ride and did not have any of the limiter strap or saging issues.
Prarie Dawg
Fox pro set up from Schmidt Bros worked for me. Installed it two years ago in my xtx.
Works great no issues. Very good customer service.
