Nytro XTX in 10 foot clamshell trailer
natedogg3
Clifton Park, NY
Hello,
new to the Yamaha world. I am looking at buying a NYTRO. I would like to go with the 144" XTX but am concerned it may not fit in my trailer. I have a 10' triton with a bearcat top. Will the XTX fit in this trailer??? Or should i stick with a short track.
thanks in advance! :-o
natedogg3 said:
Hello,
Yes, it will fit. I have a 10' clam trailer with the xtx..
The only problem you may encounter is if you replace the stock windshield with a tall, it will hit the top of the clam..
X2 - will fit length wise, but original bar & windsheild just fit.
good thing is the shield comes off really easy to put it in. or just take the whole hood off. 4 zusers and shes free
I had a 95 triton 10' trailer and it was tight but it fit. I had to put an eye hook in front and one in the back of the trailer so I could put tie-downs to the sled. If I did not do this the sled would hit the back if it moved more than an inch.
Also put a 2x4 on the floor in the front which pushed the skiis up into the front cap for clearance.
