Marmaduke2011
Has anyone had the problem of they're primary hitting the plastic belly pan? I went for a ride and everything was fine, when I came back I went to do some clutching and noticed that the belly pan is all messed up! I never hit anything that I know of, Just wondering if anyone else has had this.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
Had this happen on my wife's XTX and she don't go offtrail. The only thing I came up with was flex from long high speeds runs.
sgilbert
It will rub when plowing through snow banks
Marmaduke2011
is there anything a person can do to prevent this?
raginyamaha
put a Schmitt bros clutch gaurd plate on. Helps with the wet left foot problem on older models too. http://www.schmidtbrosmotorsports.com/y ... oot-plate/
Daranello
Suspended
APEX 06 said:Had this happen on my wife's XTX and she don't go offtrail. The only thing I came up with was flex from long high speeds runs.
I've done a 30 miles WOT run at well over 110mph with no problems
There's a tab that holds the body cover in place make sure u take the time to install correctly
