Nytro Nork
Hey guys, im looking for some help. I have a 2012 XTX Nytro. Its been stalling when i come to a stop. It doesn't do it all the time but it seems to be getting worse as time goes on. Im not getting any codes but I've run a diagnostic and tried cycling the ISC valve. It seems to be working properly but it makes a fair bit of noise. Almost like a gear slipping. Wondering if anyone else has noticed this or had the same issues?
Sounds like it may need a valve adjustment.
R00STER
- Mar 3, 2013
- Timmins, Ontario
- 2013 Nytro xtx 1.75
Any updates on your issue? It sounds kind of similar to an issue my buddy’s sled is developing.
Beenba
- Feb 16, 2011
- 2009 Nytro XTX
IACV will click when it bottoms out - its normal. You'll hear it move for a second or two, and then click once bottomed in the seat. You could have a clutching issue not letting it disengage and stalling out the sled.
Muskrat62
- Dec 19, 2016
- Cannon Falls, MN.
- 2020 SRX, 2018 MXZX, 2016 Blizzard, 2003 RX1 Turbo
Sounds like the valves need adjusting. Is it harder to start when its warm too? Cranks a few revolutions when warm but pops right off when cold. That's another sign valves are out of spec. Good luck.
M
M
- 8K
