Nytro xtx skid mods for more weight transfer
jp87
Will the star suspention mods give more ski lift as well. im looking to lighten the front under throttle. Just looking for reviews on this before I buy.
It does a little. My front end comes up a little higher than it used to since i installed the star kit. I think the transfer is a lot less restricted as well.
were is your transfer rod? look in ur manual it will tell you which way to turn for less ski pressure, I played with it one day it can make a big difference for sure!
:4STroke:
I have transfer rods max , rear spring on soft , front shock at tightest , limiter stap , on last hole.....still not enough transfer for me.
You sure you put the rods the right way i moved it almost all the way back once and she was lifting good that's for sure. add a mcx turbo than you'll have ski lift.
what track are you using? what is your clutching/gearing setup, is it stock? were and what type of snow are you riding on? elevation?
