ICULOKIN
Maybe you folks can help me understand why the new Viper doesn't seem to pull as hard as a stock Nytro.I owned the Nytro since new and rode a well broken in Viper XTX.It just doesn't seem to have the same bottom end grunt.Love the rest of the sled!
YamahaTim
- Sep 21, 2013
- Farmington, MN
- 2014 Yamaha Viper LTX SE MPI Turbo
ICULOKIN said:Maybe you folks can help me understand why the new Viper doesn't seem to pull as hard as a stock Nytro.I owned the Nytro since new and rode a well broken in Viper XTX.It just doesn't seem to have the same bottom end grunt.Love the rest of the sled!
I don't know, cause I have a turbo, but I have heard that the Nytro has a better chassis and does not have the flex that the pro cross has. So the pro cross would be giving up a little because it flexes a little more which takes away hp to the track. Now I don't know which one would win a drag race. Only way to find that out is do it. Cause you could hear five different answers. If you did it yourself you would know for a fact which one is faster.
ICULOKIN
True.I think with some clutch tweaking his sled should act like a Nytro.I think I read the ECU and calibration are Cat as well.Either way...dropping a deposit on a '15.
YamahaTim
- Sep 21, 2013
- Farmington, MN
ICULOKIN said:True.I think with some clutch tweaking his sled should act like a Nytro.I think I read the ECU and calibration are Cat as well.Either way...dropping a deposit on a '15.
Right on! You will like the ride over the Nytro though. I had a XTX Nytro and I loved it! But now that I have the LTX SE It is way better! I didn't want the XTX because it is non coupled. So I got the LTX and put a 1.6 lug track and no I got the best of both worlds!
Some clutching is alway a good thing(if it done right) and will help the take off!
stingray719
See the "CLUTCHING ANSWERS" post. After putting on 8DN my Viper really woke up. With stock belt and weights I saw what you did. (had to change to 8FS weights as I ride at 10k)
SledFreak
- Feb 7, 2005
- Ontario. Canada
YamahaTim said:ICULOKIN said:Maybe you folks can help me understand why the new Viper doesn't seem to pull as hard as a stock Nytro.I owned the Nytro since new and rode a well broken in Viper XTX.It just doesn't seem to have the same bottom end grunt.Love the rest of the sled!
Its down in hp... Its not the chassis. The Nytro in stock form is 135-138... The Viper is 130 at best. I believe it has to do with the exhaust as that motor was built around the straight exit exhaust.
stingray719
SledFreak said:YamahaTim said:ICULOKIN said:Maybe you folks can help me understand why the new Viper doesn't seem to pull as hard as a stock Nytro.I owned the Nytro since new and rode a well broken in Viper XTX.It just doesn't seem to have the same bottom end grunt.Love the rest of the sled!
Wrong, dyno tests have Viper at 137hp. The diff is the clutch, put on 8DN and correct weights and Viper blows Nytro away....I know I did it.
ICULOKIN
Thats good news!...I wanna tune my buddies Viper to show him how that 3 holer should pull !
SledFreak
- Feb 7, 2005
- Ontario. Canada
stingray719 said:SledFreak said:YamahaTim said:ICULOKIN said:Maybe you folks can help me understand why the new Viper doesn't seem to pull as hard as a stock Nytro.I owned the Nytro since new and rode a well broken in Viper XTX.It just doesn't seem to have the same bottom end grunt.Love the rest of the sled!
And you dynoed it..
fx-treme
- Jan 7, 2005
- 2014 SR VIPER LTX SE
many have hurricane, ulmer, osp, hindle. keep reading its all on here
stinkipinki
- Dec 29, 2015
- NY
- 2014 Yamaha Viper XTX SE / 1999 Powder Special 700
I came from a 09 Nytro XTX and the Pro-Cross Chassis is 10 times better.I don't know, cause I have a turbo, but I have heard that the Nytro has a better chassis and does not have the flex that the pro cross has. .
It's lighter and hooks up better.
