o6 apex with an idleing problem
travism
seattle, washington
this is on aan apex with mcexpress kit
when i start the thing it idles fine. blip the throtle it stays reved 4 and 5k rpm
think it might be the TPS anyone have this happen to them and you found the fix?
idle issue
I would check your cam timing and for intake vacuum leaks. Did it start idling high after install? Mine did and found cam timing out on exhaust by one tooth. Makes a big difference because of manifold vacuum change and the fact that the cam sensor runs off of exhaust, not intake cam. Also check for throttle cable free play for proper return to base idle position.
