problem with idle rpm with mc-xpress rearmount turbo
NORWAY
i have a idle problem after mounting a rearmount mcx turbo. after you have hit the trottle and lett off the trottle the engine will idle at 3000 rpm a while before it goes down to normal. i have cheked the carburettors and have not found somthing wrong. when i move the tps it got better. is it anybody on this site who has experiens the same problem and found the cause. plesae let me now because i dont have more to trie.AND HAPPY NEW YEAR.
Set your TPS at .70 with the switch in the off position on the handle bars.If the switch is on you will get the wrong reading.Your tps is set to high
hello and thaks for let me now. do you mean 0.7 volts? and the switch you are talking about is it the big red killswitch on the handlebars,or the little switch connected to the tors in trottlecabel. just to check i will trie it soon. and another important thing,i have not thoutched the tps after i mounted the turbo,can it move just like that or is it another thing who just have happend.
