tylerearl88
Getting close to finishing up my diy turbo kit so I figured I should try and find out what I should start with for clutching. I am using A 16t Mitsubishi turbo (rear mount) with An air water intercooler, aux fuel pump, head shim, valve timing, and neils sds fuel system. I am riding at 0-1000 ft elevation and have a 141" track. I am thinking I will be close to 200hp. What do you guys suggest for a base setup that I can work from for clutching? Can you just pile the weight to the factory clutching with bigger rivets? Also assuming I get it working right am I far off with my hp estimate?
Thanks.
Thanks.
Turk
Tech Advisor
Buy am oem aftermarket adjustable weight that can be loaded up to 70-80 grams.
