ohlins electronis shock
stubb111
Ottawa area
Canada
2009 nytro xtx
could someone send a couple pics if possible of what the controls on the handle bars looks like and wiring if possible. iam fitting an electronic ohlins into a vector (father in-law has a bad back) and can't find anything except for the shock & wire sub-lead. any help would be appreciated
thanks.....billy
I'm sure you are going to need the Ohlins control box for the vector the speedo meter doesn't have the icon for it it was just the apexs that have it good luck finding just the control box you can't just order it. You needed to buy the package complete with shock.
An alternative to using the electronic adjustment portion of the shock is to convert it to a manual adjust. There is a member here (Bjowett) that can perform the conversion and improve the ride as well.
