Mr. Miss Michigan
I just put some Ohlin fronts on my Warrior and they have a little side to side motion on them, is this normal? There was 2 washers inside the brackets when I took off the stock shocks that I couldn't get to fit back in when installing the Ohlins. The Ohlins came off my '05 RX-1 ER and they didn't have the 2 washers when I took them off. Just wondering if this is normal or if that range of motion will lead to them loosening? I don't remember if there was that motion on the RX-1.
Thanks Guys.
Thanks Guys.
Yeah I had the same problem on mine it won't hurt but if it bugs you go to the hardware store and get som plastic washers you can just put one on one side if they are too thick.
