Caribouhunter
- Nov 19, 2007
I have a pretty much stock 2006 Apex LT that has the cheap factory shocks in it. Can i just drop in an Ohlins electronic adjust rear shock? What would be needed for this install?
NY AttakGT
Check to see if you have the empty 2 pin white plug sitting to the left of the reverse reverse, under the hood. If you have the plug, should be able to just mount the shock, run the wire through the tunnel, plug it in...and you are good to go. Make sure to follow the proper routing for the Ohlins EC wire. Routing diagram attached.
