ragefarmer
will a apex ohlins mono shock fit in a rage proactive suspension
Groomerdriver
doubt it...but a call to Yami dealer should confirm. Or if somebody here has the fiche to check.
twomorestrokes
Did Rage have a ProActive? I thought the early Rage had a Pro Action and then went to Mono? Either way I wouldn't think the shock would fit a different skid design.
ragefarmer
yes it proaction, the rage is the 136 inch version, the shock is from an apex with the electronic control
p0wd3rp1l0t
rage farmer..u talkin bout an 05 rage or an 06 or 07?
ragefarmer
an 05, which i see you have also, have you done many adjustments to the rear suspension
p0wd3rp1l0t
well first of all the monoshock shock itself will not fit into our suspension....u will need to purchase two different shocks for our suspension...a center shock and a rear shock, which should be totalled together right around $850 or so. but yes i run ohlins in the rear and the adjustments are nice...i adjusted it when i bought it to max stiffness and just turned the clicker adjustment low speed a couple clicks softer and she rides alright, but handles the big stiff like no ones business. i didnt touch the spring tho
