PATFAN
Looking to see what people are having the best luck with.
SKIDOZER
I Prefer Amsoil 0w- 40 full synthetic just out of preference used the 2 stroke stuff for years with good results good price also.
trucknut
When I changed oil last season I used Mobil-1 0W-30 But I could not find it this year so I just went with the Yamaha 0W-30 semi synthetic.
BigMac
PATFAN said:Looking to see what people are having the best luck with.
Brand doesn't matter -- oil is oil.
Bakemono
Id go with any synthetic but I would stay with the same grade.
There nothing wrong with Yamalube, but the last time I checked it was only available in semi-synthetic. Thats the only part about Yamalube I dont like.
Amsoil is nice, as is Mobil 1. Castrol Syntec is good too. I used to use Castrol Syntec in my '91 Toyota 4Runner and I pulled some of the best milage ever on that rig with Syntec in it and it just seemed to run a little bit better.
The only oil I would avoid is Pennzoil. Its junky oil, in my opinion.
Tork
I use the Yamaha semi synthetic for the first year while under warrenty then switch to Mobil 1 5w-30
Tfin
Tork said:I use the Yamaha semi synthetic for the first year while under warrenty then switch to Mobil 1 5w-30
Same situation here except I switched to Mobil 1 0W-40.
4Fighter
BigMac said:PATFAN said:Looking to see what people are having the best luck with.
Personally, I use the Yamaha oil and filter.
I agree. What's it matter if you're still gonna trade it in anyway? "Longevity" - yeah right. It's still just another disposable ride, until the next big thing.
BTW: I use the Yamalube. I see no reason to deviate otherwise.
iceman9304
- Dec 19, 2005
oil type
Not sure but running the mobil 1 5w 30 might not be a good idea as this oil and most automotive oils have the little symbol friction modified.. This is not good for engines with with slip clutches such as the yammie ultrmatic atv's etc.. Also the four stroke yammie sleds have a slipper clutch for the starter and they do a NOT reccomend friction modifed oils for these engines..
Iceman
Iceman
