rtkota360
i briefly look at my sled to change the oil.Do you need to remove the side panel to drain the oil tank?06 nytro.Wheres the filter
SlowPoke
- Mar 11, 2007
- upstate NY
- www.synthetic-oil-tech.com
yes.
The filter and another drain for the crank case is located behind a removeable plate on the bottom of the belly pan.
Good luck.
Good luck.
Gone Blue
- Oct 11, 2006
- Howell, Michigan
As Slowpoke mentioned, you need to drain oil from the bottom of the engine and the oil tank. When you remove the oil filter be sure that the gasket comes off with the filter. The oil filter gaskets have been known to stick on the motor when the filter is removed and then you could wind up with two gaskets under the filter. This is not good as it will eventually leak and spray oil out. G.B.
rtkota360
what a pain in the azz,my jag has soft plugs in the bottom
