myrodman
- Feb 26, 2008
- NEW BOSTON.ILLINOIS
- 06 attak
05 warrior
Hello guys I own an 05 warrior and 06 attak and have change oil on these but my cousin purchased an 07 vector and I removed the bottom cover to drain crankcase and the only thing I see is an oil filter Is there a drain plug on this machine and if so where is it? thanks
SSX600
- Feb 13, 2010
- Richland Center WI
- 2010 Nytro XTX, 1997 Mtn Max 600, 1998 SSX600, 1975 SM292F, 1987 Inviter
I believe the vector has the same engine as the nytro and there is an allen bolt with a arrow pointing to it that says drain I believe.
canadianhunter
SSX600 is correct. If I remember it is close to the filter to the left.I believe the vector has the same engine as the nytro and there is an allen bolt with a arrow pointing to it that says drain I believe.
myrodman
- Feb 26, 2008
- 06 attak
05 warrior
thanks a lot ill take a look tomorrow
