oil change
jclee71
Northern NJ
engine is drained of oil, changed filter and cleaned screen and secured everything, i now added 2 quarts to the oil tank, where do i add the other 1 1/2 quarts to the engine, in the rubber tube breather that attaches to the air box?
no. start the engine and run it for 30-60 sec. then shut off and add oil to tank til full on the dipstick.
No all the oil is poured into the oil tank. You need to add the 2 quarts as you already did then start the sled for a minute or 2 to circulate the oil then add the remaining amount. Run the sled again for a few minutes then check your oil level.
thanks guys, thats what the manual says but ive read alot of guys add some oil straight in the engine as well, thanks again
thats what i just said :drink:
