06NytroGuy
- Sep 9, 2014
- Oswego, NY
- 2006 Yamaha Nytro
I have a 2006 Nytro and I just changed the oil in it. I noticed that it appears that I ordered the wrong Yamaha oil change kit. This kit came with a 5GH-13440-61 oil filter when I was running a 5DM-13440-00 oil filter. Are these filters interchangeable? Will I do any damage running the 5GH-13440-61 filter? The 5GH-13440-61 filter is physically longer which I would assume would give me more surface area for the filter material which should be a good thing. The only thing I don't know is what the bypass pressure is or if there are other differences with this filter. Any help would be greatly appreciated.
RobX-1
- Coldwater, OH
I'm not sure with the older Nytro models but from 2008+, the concern was that the OEM belly protector had aluminum plates down the center where the lips/edges could potentially puncture the longer oil filter. I ran the Napa Gold 1365 oil filter my 08 Nytro which was longer than stock but I also removed these plates and sanded down lips/edges and then riveted them back onto the belly protector.
theCATman
- Feb 19, 2007
- WI
- Yamaha
As long as it fits in that tight spot, it's fine to use it.
The Vectors and RS Nytro have very little clearance there for a longer filter.
I've been using the Hiflo HF147 for years now and no issues at all.
Stubbs
- Nov 7, 2006
- Uxbridge, On, Can.
+ other gooodies
- Uxbridge ON
Napa Gold 7040 works fine on the three holers as well, been using them for years and easy to find.
